B-275 Fuel system
Chris Floy
12-22-2006 08:16:50
I am trying to verify why my tractor will not run. For a period of time it would run until worked for 30 minutes or about and has got progessively shorter until now and will not start. Cleaned lift pump screen, relaced fuel filter and verified vacuum at govener. Suspected lift pump but appears to have adequate pressure at dischrge of filter housing. However when I bleed an injector line the fuel hardly dribbles much less foams or sprays. Tell me it's not the injector pump.
IH2444
12-22-2006 13:00:05
 Re: B-275 Fuel system in reply to Chris Floy, 12-22-2006 08:16:50
You might want to check for fuel in your oil...
Sounds like it could be injector pump to me.
You would might need to connect a pressure gauge to the inlet side of your injector pump. If it has good pressure coming in ? well....
