1086 HYD. problem
Jim Johnson
12-24-2006 04:52:29
Under the cab on the left side just in front of the three point is a round tube about three inches in diameter that has started leaking Hyd. fluid at a pretty good rate when I let the loader down. Was wondering what it is and what I need to do to fix it. Thanks Jim
mike old ih
12-24-2006 16:22:29
 Re: 1086 HYD. problem in reply to Jim Johnson, 12-24-2006 04:52:29
I think itis a tank for the three point just cap off the pipe on the valve
IaGary
12-24-2006 05:21:45
Jim
What year is that 10?
They changed the hydraulics in 81.
Don't know what your referring to for sure but I got one of each and can take a look here to see if I can figure it out.
Gary
Jim Johnson
12-24-2006 05:59:23
 Re: 1086 HYD. problem in reply to IaGary, 12-24-2006 05:21:45
I it's a 78
Allan In NE
12-24-2006 06:23:12
 Re: 1086 HYD. problem in reply to Jim Johnson, 12-24-2006 05:59:23
Jim,
Are you talking about the torque shaft down at the bottom of the tractor belly or is this something that is part of the loader?
Can't figure out what would leak when you lower the loader.
Allan
Jim Johnson
12-24-2006 06:42:50
 Re: 1086 HYD. problem in reply to Allan In NE, 12-24-2006 06:23:12
No Allan it's just under the cab and part of the hyd. system. I would suppose it would leak no matter what a person would have hooked up to the hydraulics I just happen to have the loader on it. It's just in front of where the three point mounts to the stem out of the housing at the top. I'm sorry if I can't explain it better, should have gotten a book on it. Thanks Jim
