bale accumulators
shane louderbac
12-24-2006 09:01:06
I am looking into purchasing a bale accumulator systems for my hay operation. I am currently looking at the rafter m equipment ten bale accumulator and the kuhns mfg accumulator. the rafter m equipment is a ten bale accumulator that uses two tie bales and stacks on a 8 foot wide wagon. The only disadvantage is that the bales drag the ground. The kuhns have a 10 and 15 bale accumulator that the bales do not drag the ground but are put up on edge. Has anyone used either one of these accumulators? If so what was your experience with the accumulators?
Fromjb2
12-24-2006 19:23:02
 Re: bale accumulators in reply to shane louderback, 12-24-2006 09:01:06
Hi Shane, way back in the 1950s we had a New Idea "bale stacker" I believe it was called. Trailed behind the baler and would hold about 10 bales, then you pulled a trip rope and it would open the back gate and release the bales all in a group. The machine was like a sled and it had rods running on the ground about 6" apart and the bales rode on the rods with enough ground friction to pull them out the back when the back door was tripped. Did not appear to damage the bales. Problem was we had two farms about 1/2 mile apart and had to load it on a wagon to transport it between farms. Only used it a couple years until we got bale chute to put bales onto the wagon.
Hope this helps
JB2
chuck46
12-24-2006 14:26:59
Hi, I have never used a bale accumulater, but have a NH 1034 automatic bale wagon for the last 20 years. Would highly recomend them, I bale as much as 25000 a year. Good luck, Chuck
