3 mechanical questions on a 1066
Willy P
12-24-2006 09:09:40
1. I have a oil leak on the power steering cylinder on just the left side can I just replace that outside seal or do I need to take the cylinder off and put a kit in it? I am having trouble getting the pin out of the axle to get the cylinder off,maybe I can unscrew the shaft out of it and then get the cylinder out? 2. I have a leak on the bottom side of the steering motor,can I just replaace the seals on the bottom or do I need to buy the complete seal kit and change all the seals? 3. The cylinder on the clutch control rod I guess is what you call it is leaking,can I buy a kit to fix it? In my IT&T manual it doesn't say anything about it,but is it easy to fix? I am keeping the tractor not just patching it up to sell. Thanks
430LPG
12-24-2006 16:27:49
 Re: 3 mechanical questions on a 1066 in reply to Willy P, 12-24-2006 09:09:40
Yes unscrew the rod from the pined end,and you"ll have to buy a complete kit anyway and yes you can just replace the end that is leaking, if you want the hard part is the get those pesky wire retainers out you have to pry the unbent end up at the groove to spin them out.2 the steering hand pump has a top kit,a quad ring,and depending on the pump type a plug with a oring on it and a bottom sealing sleeve and you should take it off and take it to someone that repaired one before because you can screw it up easy. 3 you can get a kit for it also it"s pretty easy fix if you can get those pesky wire retainers out the same as the steering cyl.
