986 steering leak
davids
12-24-2006 13:08:19
My sector is leaking oil and a kit is available. Just wondering how hard of a job it is to put the kit in. Do you have to remove the valve from the steering wheel or can you do it from the bottom side? Any help is appreicated. Thanks, davids
430LPG
12-24-2006 16:34:34
 Re: 986 steering leak in reply to davids, 12-24-2006 13:08:19
Remove it complete, Don't remove the bottom on the tractor, you'll never find all the pieces that will fall out,I've rebuilt hundreds and I would not attemp that. Then take it to someone that has repaired them before,cause you'll windup there after you do it and it won't turn(Not to insult you, there's a lot of parts in there)
