tractor tires
pgo12
12-24-2006 19:48:41
anyone know where i can get a set of 6x9 tractor tires? new or real nice. have allready tried miller. pg
Janicholson
12-25-2006 15:25:20
 Re: tractor tires in reply to pgo12 , 12-24-2006 19:48:41
Pgo that size makes no sense to me. What tractor, which end, what use, what size rims? 12.5X38 with 45 degree bars fits an H Farmall rear, a 7:50 16 fits the WFE of a 350U etc.
JimN
pgo12
12-25-2006 18:44:25
 Re: tractor tires in reply to Janicholson, 12-25-2006 15:25:20
the tires fit the front of a 1935 fairway 12. it came from the factory on rubber tires on cast hubs. the front hubs are the rims also. the hub splits in half and you slide the tire and tube on, and bolt it back together. tire size in the parts book call for 6x9. this hub is just like an early o12, or an i12. i have called a couple places and they tell me this tire size is not made anymore. ??? so i am looking for a nice used set or a new set. pg
Janicholson
12-26-2006 05:41:46
 Re: tractor tires in reply to pgo12 , 12-25-2006 18:44:25
A source is Carlisle Tire (on the web) 6.90/6.00 - 9 (TT) Part Number 554204 10pr 21.9 6.9 5.5/4.0 rim size 3665 rated load @ 125 20.2 19
This is an industrial tire That is rated for 3665 pounds of load at 125psi. It is a 10 ply tire, Others may be available. JimN
