Farmall A and B Mounted plow
Stevie J. Mote
12-25-2006 18:32:38
Hello. Hope you all can help me out on this one. I have a 1947 Farmall B and would like to know if a mounted plow from and A would fit it. Thanks for all your help.
GENE BENDER
12-26-2006 06:08:05
 Re: Farmall A and B Mounted plow in reply to Stevie J. Mote, 12-25-2006 18:32:38
No because of the hook-up from the front where the beam hooks. The A uses a wishbone type and the B uses a "U" shaped type. You wouls also need to make the roundbar that mounts between the fenders longer. I have some parts that could make it work. I am asuming it is a hand lift. if interested send e-mail
