Farmall 706 engine swap
Curt Cooke
12-26-2006 08:29:56
What all is involved with taking an engine from a combine and putting it in a 706? Will I find that the crankshaft has to be bored for the trans drive shaft? What about engine mounts?
Help!!!
the tractor vet
12-26-2006 08:42:37
 Re: Farmall 706 engine swap in reply to Curt Cooke, 12-26-2006 08:29:56
Well the ft timming cover will have to come off the replacement engine and the one off the tractor will have to go on and the rear engine plate off the tractor will have to be used along with the flywheel oil pan change and pick up tube manifold change maybe also i would use the dist. from the tractor as there maybe a timming change between a combine engine and a tractor engine if it is a gasser and if it is a diesel then change the pump .
Curt Cooke
12-26-2006 08:47:55
 Re: Farmall 706 engine swap in reply to the tractor vet, 12-26-2006 08:42:37
Vet, what about the crank. I know on the 135's and 153's when you go to do a swap in a tractor you find that the crank has to be reemed to accept the transmission drive shaft. That involves removing the crank, having it reemed, and buying gaskets and such. That's what I'm trying to avoid.
Thanks,
Curt
RR Mech
12-26-2006 19:51:32
 Re: Farmall 706 engine swap in reply to Curt Cooke, 12-26-2006 08:47:55
Im sure the pilot brg goes in the bore in the flywheel so that should not be a problem. all of that series motors flywheels will interchange.
