Main bearings on a 240U
Darin in Nebras
12-26-2006 09:55:34
Hello guys and gals, I have an International 240U with a gas burner in it. The main bearings and rod bearings need to be replaced. The crank needs to be ground. So the question is, do I have to split the tractor to pull the crank out or does it weg itself out somehow? Thanks for the input.
Thanks Darin
teddy52food
12-26-2006 10:08:18
 Re: Main bearings on a 240U in reply to Darin in Nebraska, 12-26-2006 09:55:34
Split the tractor. Impossible otherwise.
Darin in Nebraska
12-26-2006 11:59:04
 Re: Main bearings on a 240U in reply to teddy52food, 12-26-2006 10:08:18
Thanks for the input. Thats what I was afraid of. Thanks
El Toro
12-26-2006 15:33:53
 Re: Main bearings on a 240U in reply to Darin in Nebraska, 12-26-2006 11:59:04
This would be good to time to replace the clutch if needed too. Just be careful when splitting
the tractor. Hal
