Super C engine block
mostly green
12-26-2006 16:11:45
I'm working on a super C #168240 (1953). The block casting # is354898R2. It has a dipstick by the oil filter housing. However there are also test cocks on the oilpan to check the oil level. Has somebody switched the block or the oil pan? Thanks for the help.
mostly green
12-27-2006 09:19:36
 Re: Super C engine block in reply to mostly green, 12-26-2006 16:11:45
Thanks for the help guys. One thing about it I have no excuse for not checking oil with both options. Ha! Hey trw our tractors must have followed each other down the line. I have no idea how you find the build date. lol
trw
12-27-2006 06:47:07
Hey "mostly green", my Super C serial number is 168597. Do you think they might have been made on the same day? I wonder if there is some way to determine what day the tractor was made? My wife was born on Jan. 18, 1953 and she calls my tractor old. Wonder if she is older than the tractor??? On the dipstick thing, mine does NOT have a dipstick, but it does have the "plugs" in the oil pan. I think, but not 100% sure, the engine and pan on mine are original.
Jim Becker
12-27-2006 10:04:24
 Re: Super C engine block in reply to trw, 12-27-2006 06:47:07
Any daily serial number information is fragmentory at best. I have some monthly numbers from Louisville, but even that is incomplete. Both of your tractors were built in April 1953.
mostly green
12-27-2006 15:59:43
 Re: Super C engine block in reply to Jim Becker, 12-27-2006 10:04:24
Thanks for the info. It is nice to know where and approximately when it was built.
Hugh MacKay
12-27-2006 02:17:52
That block casting number is right for a Super C. Someone must have drilled it and added the dip stick.
Thumbanger
12-26-2006 16:20:45
The oil pan is the right one someone put the dip stick
CLIFF S
12-27-2006 05:01:25
 Re: Super C engine block in reply to Thumbanger, 12-26-2006 16:20:45
I have 2 Super Cs and they both have a dip stick in them and the pans are pluged, One my grandfather bought new!!
