450 Carb
Blazing Bruck
12-26-2006 19:11:10
Just picked up two identical 450 gas tractors with loaders. One tractor smokes black continuously for about an hour before it fouls the two center cylinder plugs. No amount of adjusting will clear it up. Any quick tips on what to look for inside the carb when I tear it apart? Thought maybe someone has run into this before. Thanks.
old
12-26-2006 19:42:32
 Re: 450 Carb in reply to Blazing Bruck, 12-26-2006 19:11:10
If you can turn the main jet all the way in and it still runs then you either have a float that is sticking or a needle seat that doesn't close up like it should or both. I'm guessing you know that black smoke means its running rich, way to rich. You may also have clogged jets etc. My self I would just brake down and rebuild the carb and be done with it. You may also have a float that has a hole in it also
