Wheel Swap
C W Cabalo
12-26-2006 22:44:53
What kind of adapters would I need to run 28 inch rims and centers from a MF 35 on a Farmall C ? Thanks.
Nat 2
12-27-2006 09:05:47
 Re: Wheel Swap in reply to C W Cabalo, 12-26-2006 22:44:53
Unless you are extremely lucky, and the MF35's axle is the same diameter and has the same keyway as a Super C axle, you're going to need to have something custom machined.
See, IH and MF were/are competitors. They're in the business of preventing the sale of the other guy's equipment. It's not as if they sat down and said, "Hey, let's make it so the parts from our two tractors are interchangeable!"
Nat 2
12-27-2006 09:07:48
 Re: Wheel Swap in reply to Nat 2, 12-27-2006 09:05:47
to continue...
As for a third party manufacturer making adapters, I would bet heavily that you're the first person in history who has even considered putting the wheels off an MF35 on to an IH Super C. A market segment of one does not warrant production of a specialty product, unfortunately.
Dave West
12-27-2006 06:09:47
In order to use 9 bolt wheels you could use hubs from a MM R . Find 9 bolt dishes and adapt them to your MF wheels. Just a suggestion.
