H block
Thumbanger
12-27-2006 16:18:44
Bought a H got it running runs great started looking it over behind the carb and a little below it is a nice round hole in block with a tree limb drove in it pulled limb out lost all antifreeze to check it out it has no threads what gose in this hole. Any help Thanks
TomH in PA
12-28-2006 06:26:19
 Re: H block in reply to Thumbanger, 12-27-2006 16:18:44
When I was in the Navy there was a sign on every ship: "If you don't know what it does, don't touch it".
I guess that applies to tree branches stuck into engine blocks... ;^)
Tom Windsor
12-27-2006 19:14:16
There was a thumb screw thing that went into this hole. Most of the time, the threads in this hole are shot as well as the thumb screw if it is still present. As mentioned, you can either tap this or just put a "fresh tree limb in the hole." :-)
Note: All the water will not drain out of the block by simply opening the drain on the Radiator..this was put here to get it all out to prevent freezing if you did not have antifreeze in it.
Janicholson
12-27-2006 17:53:21
If it is not a Core plug (often called incorrectly a freeze plug) it is the block drain as noted below. JimN
JayWalt
12-27-2006 18:55:54
 Re: H block in reply to Janicholson, 12-27-2006 17:53:21
I often was irritatewd by the fact that people call them freezeplugs as well. All of the frozen blocks that the plug has popped off has also been cracked. The notation that these "freeze" plugs would save a block from being cracked when the antifreeze (or more then likely straight water as people dont know what antifreeze is I guess) froze is ludicrous. When water freezes it expands as it crystalizes. This expansion is generally in all directions and takes up 4% more space. Maybe if you had one side of the block a big plate that would pop off, it might help. The water traveling through the passages to the freeze plug to pop it off is probably not going to happen especially if the water freezes starting around the plug and back through the system. These holes are to empty the sand out after casting, are they not?
Easy1
12-27-2006 20:20:03
 Re: H block in reply to JayWalt, 12-27-2006 18:55:54
At the foundries I've been in, they are called shaker holes - the block is rattled or vibrated until the sand comes out.
Yugrotcart
12-27-2006 16:34:00
Sounds like the drain hole in the block. Sounds like the threads were shot, so someone stuck a stick in the hole. Borrow or rent a pipe thread tap and recut the theads, put in a plug and away U go.
Paul
