Farmall H Mw pump
scott buckendah
12-28-2006 18:48:03
I have a farmall h that had a m&w pump on it. I took the pump off and am wondering if the belly pump will still be working. There is a hole tapped into the bottom of the belly pump where a return line went in. The preesure line looks like it went up thru the plate behind belly pump. Also I tried putting a piece from another H between the timing cover and the dist. and the holes would not line up. Thanks for any help you can give me.
chuck46
12-28-2006 19:20:33
 Re: Farmall H Mw pump in reply to scott buckendahl, 12-28-2006 18:48:03
Hi, I think everyone that went to live hyd. gutted the belly pump, so I doubt yours will work again. The hole in the bottom was the drain. If the casting you have won't fit it would be because you have a late model H and are trying to put on an early model piece or vice-versa. They changed the timing gear cover and that casting about 50 or 51. You should be able to find one that fits. If you want hyd. at all I would sure keep the live system. Good luck, Chuck
