Hydraulic Help
EKleine
12-29-2006 12:33:52
Have a Super C with fast hitch. The Touch Control hydraulic sytem just leaks all over badly. I looked at this system in the parts manual and I just scares the living daylight out of me with the large number of small parts, O rings, seals etc. that it has. My question is, are these relativly easy to take apart and replace the worn parts? Any special tools required? Is there anyone who professionally rebuilds these? Can parts be obtained yet? I just bouht this tractor and want to eventually paint, but not leaking the way it does. Any feedback is appreciated. Thanks, EK
CNKS
12-29-2006 13:37:49
 Re: Hydraulic Help in reply to EKleine, 12-29-2006 12:33:52
The hardest part is getting it off the tractor, the second hardest part is getting the head to break loose without garfing it up. A repair kit costs about $100. You need a diagram out of the parts manual to see how it goes back together, unless you have a photographic memory. It's fairly simple, just takes time. Keep everything clean.
CNKS
12-29-2006 13:36:43
