Super C update!!!!
Patrick in Illi
12-30-2006 11:05:57
Just wanted to give a little update on the rebuild of my 51 Super C motor. pulled the sleeves and pistons this morning with very little trouble. Found a 1" layer of crud in the water jacket. Rod bearings are .002 so not original. Going to have the block cleaned professionally. Sleeve seals are shot, so you all were right about my antifreeze in the oil. :) I am going to order a rebuild kit from this website and attempt my first rebuild. Thanks for all the help in the past and thank you all in advance for my future questions. !!!!Happy New Year!!!! Patrick
El Toro
12-30-2006 11:29:55
 Re: Super C update!!!! in reply to Patrick in Illinois, 12-30-2006 11:05:57
Have that crankshaft measured at your local auto machine shop. They can determine after measuring it, whether you can still use .002" undersize bearings or the shaft needs to be ground .010"
undersize. That's a smart decision to have the block cooked and cleaned.
Those old sleeve seals get hardened like an old shoe left out in the weather and with a clean block and new seals should solve any coolant leakage from that area. Hal
