plumbing a priority valve
Frank Packard
12-30-2006 15:21:14
OK guys here it is, I just got a priority valve and I am going to plumb it on sun. I am putting between the hyd. pump and my hyd. valve block. Putting main line in the adjustable flow port putting the "out line" to the charlyn motor. Putting the excess flow line to my hyd. valve. Using the valves return line to take everything back to the sump. Does it look right to you? If not any advice will be appreciated. Thanks, Poor Farmer
Allan In NE
12-30-2006 16:13:34
 Re: plumbing a priority valve in reply to Frank Packard, 12-30-2006 15:21:14
Nothing dumps from the priority to sump if it is a 3-port valve.
"In" is pressure line from the pump. "Exhaust" is then the "in" to your hydraulic valve and the "CF" goes to the input of your steering motor.
The exhaust of your steering motor goes to sump as does the exhaust from the hydraulic valve bank.
Allan
Frank Packard
12-31-2006 06:45:18
 Re: plumbing a priority valve in reply to Allan In NE, 12-30-2006 16:13:34
Thanks Allan Yes I meant that I was using the valve body to dump the excess from the valves. Just wanted to make sure I had all of the lines on correctly. Thanks, Poor Farmer
