IHC 574
Wayne Rogers
12-30-2006 19:56:55
Can anyone tell me about an IHC 574 tractor. Year made and HP. Thanks Wayne
Retcol
12-31-2006 13:11:04
 Re: IHC 574 in reply to Wayne Rogers, 12-30-2006 19:56:55
I owned a 1972 574 gas Row Crop. They were also available in utility style. I had mine overhauled at 4000 hours. I liked the tractor for ease of operation. I pulled 3-14's mounted plow and a 10 foot disk with it. We baled alot of hay with it too. My wife hated the tractor because the transmission would get so hot and she thought it was too noisey. I had problems in the winter with gas line freeze. My other old Farmalls would start but not that one without a bottle oof HEAT in the tank.
Harold Hubbard
12-31-2006 06:19:39
Let me chime in here with yet another rant about the 574.
In my opinion, excellent loader and utility tractor, very maneuverable, left hand control on the shuttle shift, and easy to get on and off.
Hottest thing this side of an oven if you use it for extended operation in haying or tillage in hot weather, worse if you have a loader on it, worst if it is the gas model.
Before you buy one make sure that the parking brake works, or figure on a two day thrash to replace it, and get the remains out of the hydraulic system. Once the parking brake works, get a strobe light about the size of a lighthouse, and hook it up to the parking brake indicator. The brake holds the tractor from rolling quite nicely, but it can be overpowered by putting tractor in gear and taking off. After a few incidents of this the $200 brake band will disintegrate and distribute itself throughout the transmission and hydraulic system, eventually plugging the filters, or something more expensive. The service brakes will do this also, but they will last a long time before it happens.
On the particular tractor I am familiar with, both front spindles have been replaced, but I am sure that is from operator abuse/accident. It was previously owned by a young man who loaned it out indiscriminately among his friends and casual acquaintances. This, in itself, indicates that except for the parking brake problem, it is a relatively tough and trouble free machine.
Mike Van
12-31-2006 03:32:10
Wayne, i have a '75 574 gas, bought it new. C 200 engine, 51 hp i believe. Good tractor.
Hugh MacKay
12-31-2006 03:51:58
 Re: IHC 574 in reply to Mike Van, 12-31-2006 03:32:10
Mike: Interesting, what I found in the buyers guide suggested no gas 574, however I seem to remember these in gas models at dealer back when new. In those days I wasn't shopping for 50-60 hp tractors, thus didn't give 74 or 84 series tractors much attention.
I personally wouldn't touch one of those C-153 or C-200 engines if planning to do much heavy work, or log on big hours. I was farming full time with 8 relatively new tractors back when those were new. Those two engines had a poor reputation well known to IH customers before they were 5 years old.
kj(SE IL)
12-31-2006 09:04:50
 Re: IHC 574 in reply to Hugh MacKay, 12-31-2006 03:51:58
the gas 574 has the c-200, not the best ih engine ever built, sleeveless, they are very hot on the left side of operater station for sure.especailly when working hard on a 7ft hog in tall heavy grass. carb and gov not the greatest.kj
Hugh MacKay
12-31-2006 10:49:21
 Re: IHC 574 in reply to kj(SE IL), 12-31-2006 09:04:50
kj: Try 1,500 hours to the first engine rebuild, that is what they were known for in the late 70s. We had been used to old 300 gassers good for 4,000 hours each and every time, and put em on a 3 bottom plow, the 300 looks good.
Hugh MacKay
12-31-2006 02:43:30
Wayne: The 574 is in a 1975 buyers guide I have. If I remember correctly the production run on those ran from 71-72 through to 76. The diesel was 239 cubic inch, with IH calling it 54.8 pto hp. It was also built as a hydro model, rated at 56 pto hp. In looking over the data in this buyers guide, they don't list a gas version of the 574. Interesting the size larger 674 was available in both gas and diesel, but not hydro.
Other specs include 8/4 synchromesh transmission, plus optional TA, 11 inch clutch, wet hydraulic disc brakes, Cat.II 3 point hitch and 540 - 1000 rpm pto. I expect that pto was twin shaft, however the guide doesn't say.
You may want to ask some questions about hydraulic, transmission and rear end. I saw some discussion on here awhile back, something to do with brakes or pto, seemed like a major tear down for a small fix. I didn't pay close attention, thus cant tell you the exact details. Someone will probably chime in on that one.
I've never heard anything but good about that 239 diesel, it was used in several tractors and subsequent models, at least to the Case buy out in 84-85. I'm not certain, but think Case continued to use it well into the 90s.
