Farmall A clutch reassembly
bigr
12-31-2006 10:57:05
I"m restoring an "A" and put the block back on the bellhousing with the new clutch installed. Just thinking out loud but if the tractor is in gear, and you turn the wheel disc, shouldn"t the flywheel turn also? I"m thinking it"s the same thing as rolling the tractor and popping the clutch to start it. My flywheel doesn"t turn, and the clutch is adjusted right. Did I do something wrong, or is it normal. First tractor I"ve had apart this far.
bigr
12-31-2006 12:36:02
 Re: Farmall A clutch reassembly in reply to bigr, 12-31-2006 10:57:05
No, I didn't. Guess I'll have to pull it back apart. What bolts are these and where are they located? Thanks for the info!
Red Dave
12-31-2006 14:05:58
 Re: Farmall A clutch reassembly in reply to bigr, 12-31-2006 12:36:02
There are usually 3 bolts that compress the pressure plate springs that effectively release the clutch. They need to be removed after the pressure plate is installed and the disk is lined up with the pilot bearing. Once they are out, the disk is held tight against the flywheel.
Red Dave
12-31-2006 11:20:26
Just a guess, but did you take the spring compressing bolts out of the pressure plate after you lined the disc up with the pilot bearing?
Janicholson
12-31-2006 11:07:58
Yes if the pedal is out, and the clutch is readjusted to compensate for the fact that the new disk is in there, it should try to turn the flywheel. JimN
