Need M hydraulic pump!
Granger
12-31-2006 11:33:10
I was out plowing snow today that was left over from the two snowstorms that went thru here in WY in the past couple weeks & my hydraulic pump cracked in half & was slewing oil ALL over. Just wanted to see if anybody had one for sale on here? It is an IH pump (not the M&W) with the hoses feeding into the bottom of the pump. The part number is #12819OC91. Thanks for any help.
Bruce Wa.
01-01-2007 11:46:37
 Re: Need M hydraulic pump! in reply to Granger, 12-31-2006 11:33:10
Check your relief valve before you run the new one. If it is stuck you will split the new one also. I ruined a pump like that for this reason.
Ed Cunningham
01-01-2007 05:34:58
Farmall M never come out with a live hydraulic pump,The part number you have is of a late super M and 400,450 farmall. I have a good hydraulic pump of a runing 400 farmall. the rearend case is bad so im parting the farmall 400 out.E-mail me for price and shiping.
MN Scott
12-31-2006 20:02:17
Well you have three choices. Find a used one, salvage yard like steel wheel ranch, ebay ect, Buy a new one from CIH. I priced one for a Super H from CIH, $1500, ouch!! Or buy a new aftermarket one for around $600. A&I, Steel Wheel Ranch or any number of places maybe even this site. Good Luck!
