Farmall 27V Sicle Bar Mower
BGDean
12-31-2006 16:25:08
I'm looking for a manual for the 27V. going to try and convert to a 3pt. mount. Picked it up at auction for $50, looks complete but not sure how some of it goes together yet.
El-mar
01-01-2007 09:38:50
 Re: Farmall 27V Sicle Bar Mower in reply to BGDean, 12-31-2006 16:25:08
Have a origianl manual for the 27v if you have not found one. not a regular user of this site but think you should be able to e-mail me.
TomH in PA
01-01-2007 08:36:16
I have a manual for a 25V, probably pretty close.
How many parts is it in? Or what are you trying to take off?
A couple of things I can think of that are confusing:
The castle nut at the back is left-handed thread.
The big arm that holds the bar and pivots is threaded into the housing (that's right, the thing's about 2 1/2 inches in diameter and screws in).
BGDean
01-01-2007 09:48:51
 Re: Farmall 27V Sicle Bar Mower in reply to TomH in PA, 01-01-2007 08:36:16
TomH,
It"s fairly well together. The hydraulic cylinder is off and there is a long bar about 3/8" dia. bent 90deg on one end with a pulley block on it. I assume thats for the rod to slide on when raising and lowering. Not sure how that fits. Thinking about removing the drawbar attachment and adding some steel to pickup the top link of the three point. The V shaped frame looks about the right width to fit the lower arms. Going to use it on a compact New Holland. If I put a drawbar on the three point I"m concerned about the rotation of the drawbar, won"t be fixed like an old H or M has.
I think the 25V was pretty much the same but maybe with a manual lever to raise and lower. Would you be willing to part with it or make a copy?
Berry450d
01-01-2007 07:37:54
I found a model 31 at a sale cost me a fortune 8 bucks it even had anew pitman rod wired to it.The price tag was still on the pitman it said 12.99.Wouldnt dream of cutting on it they are not hard to put on tractor and really look good painted correctly red and blue.Good Luck
Brownie450
01-01-2007 04:30:56
If you don't get any takers, let me know & I'll copy ours.
Don L C
12-31-2006 20:22:48
I guess the three point would be easier to mount and dismount, but I would leave the raising and lowering alone..... ..
