Order Farmall Cub Parts Online
Cub Tires
Atvman
12-31-2006 18:05:43
I got a cub with 8.3x24 tires on the rear. I found some cheap 9.5x24 tires. How do these tires work compared? Will they hurt the power or anything bad?
jeffcat
12-31-2006 23:02:57
 Re: Cub Tires in reply to Atvman, 12-31-2006 18:05:43
If you have a mower deck on your machine you may need to relevel the deck. I think if you have the machine on a dead level floor there is a spec. Should be something like 1/2 in from front to rear of blade. You want the front of the blade to cut only one time.The rest of the blade will catch any misses. Jeffcat
john cub owner
12-31-2006 19:08:43
Thye are lightly taller and wider, but not enough to create a problem in most circumstances, unless your wheels are all the way in.
