Super M 12 volt - again
jeffalex2
12-31-2006 19:38:35
I must have a short somewhere. The ammeter still swings hard positive while the tractor is running. The strange thing is it only does it while running...I haven't tried disconnecting the battery while it's running to see if the ammeter swings back to center...will she keep running w/o the battery connected?..and run off of the alternator?
Jossette
01-03-2007 19:16:12
 Re: Super M 12 volt - again in reply to jeffalex2, 12-31-2006 19:38:35
third party image
It may just be wired wrong.
Brownie450
01-01-2007 04:28:45
If you have a Delco 10SI alt., if the internal regulator is good, check for battery voltage at the #2 terminal[flat blade connector ] on the internal regulator. This terminal reads battery voltage for the regulator, & if it doesn't have battery voltage, it assumes that the battery needs as much charge as the alternator can deliver. If there is no voltage at #2 terminal, you have an open wire or a terminal end not making contact somewhere in this circuit.-- Between the battery & #2 yerminal. If this terminal[ #2] has voltage, the regulator is most likely bad.
jeffalex2
01-01-2007 04:47:56
 Re: Super M 12 volt - again in reply to Brownie450, 01-01-2007 04:28:45
Thanks...i'll check that out...may i've got a bad connection and the alt. thinks that the battery is dead...
jeffalex2
01-01-2007 04:22:22
Thanks guys...I had a previous post. I have a Super M that's converted to 12volt with a 10si alternator. The battery and the alternator both check out, but, the ammeter swings full + while the tractor is running. I checked the internal diode on the alternator, also is OK. Trying to figure out where the juice is going...really puzzled.
old
12-31-2006 20:20:15
Yes it should keep running, but the amp gauge should also peg on the charge side if you do that and you can/will burn out the alterntor if you do that since it will see a dead battery and do its best to put out max amps becuase of it. DON'T try it unless you want to buy another alternator.
Jim West TN
12-31-2006 20:18:51
While it is true you can sometimes get away with disconnecting the ground lead on the battery with a system that has a generator to see if the generator is putting out without hurting anything, if you do it with an alternator system you will probably blow the diodes or burn out the windings. If your ammeter is indicating it is charging 20 amps you already have a good indication the alternator is putting out. Read across the battery with a voltmeter to find out what is going on.
HTH
Jim
