M and 450 narrow front interchange??
migraine
01-01-2007 21:15:17
Just got in 450 Farmall with Scwartz wide front but I like to keep things original and I have a like new tricycle front off an M or Super M. Is this a direct swap with matching 4 bolt patterns. Have the hubs and wheels but will need the rims and tires. Thanks for the help. Migraine
Paul in Mich
01-02-2007 14:54:23
 Re: M and 450 narrow front interchange?? in reply to migraine, 01-01-2007 21:15:17
Migraine,
The only thing I might add is that the pedistal itself is interchangable, but some of the older M"s had the old style hubs which would not allow for the 2 inch adjustable increments of the later hubs. To my knowledge, the 450 used only the later hubs. They are distinguishable by their lack of the seating ring on the back of the hub wheel that was on the older models. The rims for the later hubs also require the stand off bolt mounts.
Alvin Dick
01-01-2007 21:31:52
They will interchange, even the 560 would interchange.
John A.
01-01-2007 21:30:24
migraine, It should bolt straight up. That same pedistal was used for the Ms up to the 806s, if I haven't taken leave of all my memory. Hope this helps. Later,
John A.
