806 Hydralics
Filo Coats
01-02-2007 09:56:50
I have an 806 with dual hydralic levers. Both will move a significant distance to the rear and have good fluid flow. However, they will only move a short way to the front and have slow fluid flow. There is what appears to be a bolt for adjustment with a lock nut under the handles that would allow more movement. Will adjusting this allow for more fluid flow? If not, what can I do to increase the fluid flow?
Thanks,
Aces
01-02-2007 11:13:26
 Re: 806 Hydralics in reply to Filo Coats, 01-02-2007 09:56:50
Filo The adjustment is so you can have float down. Some one must have the screw adjusted out to far. Back the screw off some you should have as good a flow one ways as the other.
Filo
01-02-2007 11:56:13
 Re: 806 Hydralics in reply to Aces, 01-02-2007 11:13:26
Thanks, Aces. I thought I should. I just wasn't sure about the adjustment.
