F-20 Variable Speed Governor
GAUU6
01-03-2007 15:03:58
I recently purchased a 1937 F-20 and the throttle (governor control)is on the right side,not behind the steering wheel. There is no throttle control rod attached to the lever at the end of the gov. rod support,it"s just hanging loose. I assume this is the variable speed governor set up. Anyone know if anything should be connected to the lever where the throttle control rod once was?
Farmallgray
01-05-2007 08:26:30
 Re: F-20 Variable Speed Governor in reply to GAUU6, 01-03-2007 15:03:58
I believe the ones on the right side were an aftermarket setup. All the factory setups were on the left side. As long as it works ok, nothing would need to be hooked to that lever.
russ hamm
01-03-2007 16:51:16
some kits came with a cover to replace that one without the lever. it can hang loose or a cover without can be had.
