15/30 S/No. Location
Nigel Apperley
01-04-2007 02:56:33
Recently acquired a 15/30. The S/No. plate has been ripped off. Is the Serial number stamped anywhere?
Loren in Iowa
01-04-2007 06:33:38
 Re: 15/30 S/No. Location in reply to Nigel Apperley, 01-04-2007 02:56:33
Check the engine block, toward the front. There should be a flat spot, I believe, on the right hand side. This serial number might match the tractor's serial number, which probably isn't anywhere else on the tractor. Without the serial number plate, this is as close as you can get to determining the actual serial number, unless the engine has been replaced. You may find some casting dates on the engine, or the gear case, that will give you a clue to the age of the tractor. We used the engine number, and had a new plate made, for our 15-30.
moseed
01-04-2007 06:32:46
It's interesting which IHC models make us think "now thats my idea of what a tractor should look like". It is very individual for each of us. The 10-20 and the 15-30 say it pretty well for me.
Congratulations and good fun to you!
El Toro
01-04-2007 08:58:33
 Re: 15/30 S/No. Location in reply to moseed, 01-04-2007 06:32:46
They were both excellent tractors too. Hal
El Toro
01-04-2007 04:00:37
Look on the left side of the clutch housing or the transmission housing. Hal
