last Farmall
Garlan111
01-04-2007 11:08:00
What was the last tractor produced that had Farmall on the hood as the brand name, like the 1206 mayby? Any info is appreciated.
Garlan111
01-04-2007 15:13:16
 Re: last Farmall in reply to Garlan111, 01-04-2007 11:08:00
At some point the main nameplate on the hood went from FARMALL to INTERNATIONAL, as far as Ertl toys go, i"ve seen a 1206 with Farmall on the hood then a 1256 with international.
thanks for anymore info.
Hugh MacKay
01-04-2007 16:38:00
 Re: last Farmall in reply to Garlan111, 01-04-2007 15:13:16
Garlen: I think you already have it, all but 140 and 656 changed at end of calendar year 1967, and the 140 and 656 changed sometime during the 1st six months of 1968.
Garlan111
01-05-2007 00:39:47
 Re: last Farmall in reply to Hugh MacKay, 01-04-2007 16:38:00
i appreciate the info yall.
Hugh MacKay
01-04-2007 14:00:22
Garlan: I disagree slightly with Jim. Basically all Farmalls had FARMALL as the main hood designation end at the end of 04-06 series at the end of 1967. There were two exceptions and they didn't change until sometime mid 1968. The two are 140 and 656, which one was last I'm not certain. No one has ever put forth information, that I can see proves this either way.
140 would definitely been the last to have Farmall on the model badge.
Nat 2
01-04-2007 13:57:47
The '06 series is the last to have FARMALL in a large format on the side of the hood. In the '56 and for most of the '66 series, the FARMALL was relegated to a small band above the model number on the hood "doglegs."
Farmall completely disappeared from the tractors in 1976 with the introduction of the "black stripe" '66 series tractors.
Jim Becker
01-04-2007 11:48:35
140 but by the end it was on the model emblem, not the side of the hood.
