Removing 450 radiator
Alan in VA
01-05-2007 12:30:37
How do I go about removing the steering rod that goes through the radiator on a 450? Any help would be greatly appreciated.
Berry450d
01-05-2007 12:55:04
 Re: Removing 450 radiator in reply to Alan in VA, 01-05-2007 12:30:37
Alan you must seperate the steering shaft at u joint. On front steering post there is a plug at the top that wrench will fit on remove plug and shaft will unscrew comming out the front of steering post. Good Luck.
