450 throttle solution
vigar farms
01-05-2007 19:03:24
I've got the fix to 300-450 model tractors throttle not staying where you put it when they become worn. and it never changes any thing visible with the hood on.
PORKY B.
01-06-2007 21:50:44
 Re: 450 throttle solution in reply to vigar farms, 01-05-2007 19:03:24
Not trying to be judgemental over your linkage fix, but I prefer to leave it original. The governor and linkages can be easly repaired. Does not matter how wore out I have found them.With time and some decent materials, works and looks like the originals.
champspa
01-06-2007 05:23:49
Ok, I'll bite what is it
Brownie450
01-06-2007 04:41:29
Is the hand operated throttle control up by the steering wheel slipping or in the governor itself??
PORKY B.
01-05-2007 19:32:05
And just what would that consist of?
vigar farms
01-06-2007 06:18:25
 Re: 450 throttle solution in reply to PORKY B., 01-05-2007 19:32:05
It is a different linkage and a friction disc that fits between the fuel tank and the engine.
Made a prototype and it seems to work good.
