Questions for 350 Diesel Owners
migraine
01-06-2007 08:59:25
I plead a bit of ignorance here as we never owned or had use of 350 Diesel with continental motor. What was used as a starter aid in cold weather. I know it does not have glow plugs so was it a manifold air warmer or??? Do they start ok if everything is working? How was the power on this 193 motor and can you tweek them up a bit with fuel and rpm? Have chance to get a complete motor with pump,lines, manifolds and filters and kinda looking for some feedback from current and past owners. This motor was in a utility and I want to install it in a row crop. I have all the manual frame sheets and it appears that there was frame supports that held up the front of the motor. Any ideas where to find a pair of those and was the water pump and fan assembly interchangeable with any other models? Sorry about the long post but sure could use some help here. Thanks Migraine
Merle Hoppenworth
01-07-2007 10:06:32
 Re: Questions for 350 Diesel Owners in reply to migraine, 01-06-2007 08:59:25
I had one and once I looked in the book and found out just how long you had to hold the heater on it started very well. Just look at your watch when holding the button, 1 minute takes longer than you think.
r4etired
01-06-2007 20:00:09
Migrane, Don't think you should use either on the continental engine, it has the energy cell injection system, I know you can,t turbo them. If I remember correctly they called the energy cell injection the Lunar( or something close) system after the guy that invented it.Diesel guys can tell you more about this, been a lot of years ago I had mine.
Berry450d
01-06-2007 20:06:45
 Re: Questions for 350 Diesel Owners in reply to r4etired, 01-06-2007 20:00:09
It does have energy cells,but the manifold heater is a factory piece and works well.
Seeing Red
01-06-2007 15:05:18
If the compression is good and the timing is correct , they start rather easily. Mine has a manifold heater that does the job. At 70 degrees or above it needs nothing.
Charlie M
01-06-2007 12:29:34
My Dad had one in the 60's and pulled 3-16 plows with it. Always had to use ether to start his when it was even just cool outside but it always started.
Berry450d
01-06-2007 09:33:57
The 350 diesel has a electric manifold heating element in it. Mine starts very well in all weather.The GD 193 engine has power to spare.The fuel can be turned up a little. I dont know about motor mounts,but water pump is different and quite expensive.The hydraulic pump and hood panels are also different.Good Luck
