F20 Timing Gear Lub Tube
ET
01-06-2007 12:45:53
I am reasembling the timing gear train on my F20 engine and I don't remember what direction the oil drip tube was pointed. Is it just bent down enough to drip oil on the middle of the crankshaft gear or is it rotated towards the camshaft gear to get oil where the two gears run together?
Nebraska Cowman
01-06-2007 15:26:39
 Re: F20 Timing Gear Lub Tube in reply to ET, 01-06-2007 12:45:53
I'd say it wants to be directed to oil the bearing. Then the excess will be slung off and lube the gear teeth.
