300 row crop behlen power steering
ohio river farm
01-06-2007 15:50:37
I have a behlen power steering motor. What do I have to do to the hydralic valves to install this on a 300 without power steering?
ohio river farmer
01-07-2007 07:20:32
 Re: 300 row crop behlen power steering in reply to ohio river farmer, 01-06-2007 15:50:37
Thanks for all the information.
D Slater
01-06-2007 18:16:14
For the way IH did it you need the control valve last one on inside from order of removing. Regulator,safety,priority valve and pipe and fittings to connect the two. Orfice plug,Return hose and fittings to connect oil return line to reservoir drain plug hole,pressure hose,brace to keep hydraulic motor body from turning and front steering shaft or shorten yours to work.Coupling for steering shaft. Bunch of orings. Unless you want original get a power steering pump with reservoir, it will fit on top left side of 300 engine and run off a longer belt and you can just run hose to the behlen unit.
Tim Shaw
01-06-2007 17:53:47
In addition to the steering motor you need the priority valve, inside hydraulic remote, U-shaped jumper line, shorter steering shaft and coupler, plus the lines to add factory power steering. I added it to my 350 last winter. I just ebayed the complete set up from a donor tractor.
Berry450d
01-06-2007 17:13:50
You will likely need to add a flow comtrol valve.
jpl
01-06-2007 16:03:59
I have a 300 row crop, I can look at it in morn and see how its hooked for you. am in circleville area here. i;ll answer sunday am.
