135 head--Stan(VA)
Chris from Wa
01-07-2007 10:14:51
Stan(VA) you mentioned putting an early 9 bolt 135 head on a 123. I understand that the 135 head has bigger valves and smaller combustion chambers. How much power increase over stock can I expect from a 123 with a 135 head and the Tisco 3 1/4 overbore p&s kit with stepped head pistons? Is the 135 head a straight bolt-on? Do you know where I can find the correct 135 head? Does anybody have one?
CLIFF S
01-07-2007 15:06:38
 Re: 135 head--Stan(VA) in reply to Chris from Wa, 01-07-2007 10:14:51
Yes they Bolt on! Use the Manifold too and with the 3 1/4 pistons give you 133 cid and simular power to a 135 if set up properly!
Chris from Wa
01-07-2007 15:39:49
 Re: 135 head--Stan(VA) in reply to CLIFF S, 01-07-2007 15:06:38
Thanks CLIFF S.
