300 utility pto need help.
Sunny 4 acres
01-07-2007 11:53:44
I have been working on my international 300 utility. I have a pto where the lever is on the right side of seat. I found the seasonal disconnect. I pulled the bands out because it would not disengage band adjustment did not help. My question is what is the thickness on the bands suppose to be? Where can I get new bands from? Maybe my existing bands are good but I need to know the thickness of a good band to go off of. Thanks a million guys.
Janicholson
01-07-2007 18:58:51
 Re: 300 utility pto need help. in reply to Sunny 4 acres, 01-07-2007 11:53:44
I do not know the thickness: The way we determine the usefullness of the bands is if the adjustment (under that small shell like cap) will no longer work. Look in this forums archives (search for) 300 PTO adjustment. It is tickelish, but works. If they are worn, a good brake shop, or industrial equipment repair shop will reline them. Cranes and winches almost all have band clutches that have similar linings. JimN
