rear cover gasket or ?
Randy as in Ran
01-07-2007 15:29:31
Hi , Is there any reason that the rear cover can't be sealed with some flavor of RTV sealant ? Or is the gasket there as a spacer ? Thanks ...Randy
Nebraska Kirk
01-07-2007 19:29:36
 Re: rear cover gasket or ? in reply to Randy as in Randy-IA, 01-07-2007 15:29:31
RTV sealant works just fine. I used it on the tranny cover on both my H and M without any problems. I will say that you do need a gasket where the belt pulley attachment bolts to the top of the tranny cover, otherwise the gears will mesh too tight and you can"t engage the belt pulley.
