41 H Farmall shutters
thumbanger
01-07-2007 16:16:40
Will 39 H shutters work on 41 H
kfox
01-07-2007 17:28:07
 Re: 41 H Farmall shutters in reply to thumbanger, 01-07-2007 16:16:40
In the parts book, it looks like the shutter & monting frame will work but the control rod & cranks had a change at serial # 38151, and again at serial # 70409. I think the crank was mounted on the rear gas tank support up to # 38151, and was moved back to the plate on the bottom of the steering post on later models. Probably someone on here can give you a better answer. ken
