a different angle
Randy as in Ran
01-07-2007 19:04:16
Hi , Can RTV silicone be used for sealing the tranny cover on a M or is the gasket needed for use as a spacer for some reason ? Thanks ...Randy
Janicholson
01-07-2007 19:29:41
 Re: a different angle in reply to Randy as in Randy-IA, 01-07-2007 19:04:16
I do not think it will cause problems. I would clean the cover surface to bare metal and put a very thin whisp of chassis grease on the trans/dif casting. This will allow the RTV to seal, but come off when needed. It also allows the RTV to be on the cover for cleaning. Use only a skim coat, gobs of it comming out in the trans can get into places it is not needed. I would also use it under the bolt heads on the cover to keep water out of the casting (as much as possible). JimN
CNKS
01-07-2007 19:27:37
It can be, but I really prefer to use a gasket coated on both sides with copper coat or a similar "sealer". Those areas usually don't leak much, though, so you are probably ok.
