WK -40 Manifold Question
Shawn ERickson
01-08-2007 07:59:50
I am a teacher at an ag school in SE MN. We are doing some work on a students wk-40 Serial # wkc3489 with a red diamond 450 Serial # 11135. The student does not think that this is the original engine. Does anyone know if it is? If not was this from a truck? We are in need of a manifold for this engine. Will an original manifold from a wk-40 work on this engine?
M Wall
01-09-2007 05:09:33
 Re: WK -40 Manifold Question in reply to Shawn ERickson, 01-08-2007 07:59:50
We made a manifold for one of our Wk 40's . Yes the 450 takes the same manifold. Yes you can still find starters for WK 40,s.
wk-40
05-24-2007 08:41:03
 Re: WK -40 Manifold Question in reply to M Wall, 01-09-2007 05:09:33
will a R-190 truck manifold bolt up to a wk-40 with a red 450 engine
Allred1
01-09-2007 08:45:24
In regard to a starter. Do you happen to know brand name and model # ??
Do you know of anyone or anywhere where we can purchase one?
Thank you
allred1
01-08-2007 19:18:56
This is a little OT. My son has a 1936 WK 40. Bell housing has place to mount a starter. Is there a starter available at this point in time that will fit or any orginal ones around?? Any help or suggestions appreciated.
Mike Androvich
01-08-2007 16:05:14
The retrofit of a Red Diamond truck engine into the WK-40 tractor was a very common method of making this tractor into a real workhorse. While a nice engine to hear run, the original was lacking power for some applications. Also when it came time for a rebuild, truck parts were more common than ag parts so the impetus for a changeout was there. As for the manifold commonality, yes, the manifold from a tractor engine will fit onto the Red Diamond 450 head. The head is only 1 piece whereas the tractor head is 2 piece, but it will make no difference to the manifold. These manifolds are very hard to come by and extremely expensive for replacements. Hopefully your manifold is OK.
randy hall
01-08-2007 09:35:57
yes your engine came from a truck. the original engine is 298ci. i have 2 1/2 wk-40's right now. i don't know about the manifold from a 450. the 401 will switch but not sure about the 450.
Berry450d
01-08-2007 08:35:41
I dont think it is original either.I had 6 inch irrigation pump that had a Red Diamond engine in it dont know if it was original or not,but it had headers and no muffler loudest thing i ever heard run could hear it from miles away.
RustyFarmall
01-08-2007 08:15:56
I am more or less guessing here, but I think your student is correct. The red diamond engine would not be original. For more help, visit oldihc.org or the red power magazine website.
