Grill mis-match-trade?
Roger Mills
01-08-2007 11:37:17
I have an A with what looks like the wrong grill on it. The right side does not have the curved releif for the steering box and it only has one small hole in the center top front for the emblem. I believe this to be a C grill not a B and it is certainly not an A. If someone needs this one I would trade for the correnct grill. The grill is in good shape but is cracked where the lower front mount bolt goes thru.
Hugh MacKay
01-08-2007 13:38:18
 Re: Grill mis-match-trade? in reply to Roger Mills, 01-08-2007 11:37:17
Roger: One small hole at top for emblem would indicate a SUPER with the small IH emblem. I think the Farmall emblem across the top had two holes. Not positive on that, but can't see how that 10" long Farmall emblem could have stayed tight all these years with less than two bolts.
Hugh MacKay
01-08-2007 13:37:39
Roger Mills
01-08-2007 20:53:06
 Re: Grill mis-match-trade? in reply to Hugh MacKay, 01-08-2007 13:37:39
There is a C down the street #68615 and it has an IH emblem about 2" wide and high center mounted with one hole in the grill. It is exactly like the grill I have. You are right-the Farmall emblem and the International emblem use two holes. That is why I think the one I have is an original C grill not a B. It does not have the curved releif for the steering box so it cannot be an A. If someone wants the C grill and has an A grill I will pay shipping both ways.
