M belt tension
JUG
01-09-2007 04:13:18
How tight should the water pump belt be?
JUG
01-09-2007 10:00:29
 Re: M belt tension in reply to JUG, 01-09-2007 04:13:18
thanks for the info
Haas
01-09-2007 06:42:41
The manual says 3/4 to 1 inch of slack at the center of the belt between engine pulley and WP pulley. That means belt can be pushed in 3/4 to 1 inch at that center point. That is not real tight.
Wisconsin Cowman
01-09-2007 05:55:42
Take your finger and push on the belt. If it has a little push to it. Then it is just fine.
