340 antifreeze leak
Mark / Wi
01-09-2007 11:04:39
When it is below freezing and the 340U has been standing for a few days it will leak antifreeze. Some from the front of the engine and some from the rear. I think the front may be leaking from hoses (not sure) but there are drips back by the bell housing area also. Any ideas what could be leaking, front or rear? Thanks in advance for your help.
Berry450d
01-09-2007 16:15:46
 Re: 340 antifreeze leak in reply to Mark / Wi, 01-09-2007 11:04:39
Dont laugh I let my Super C freeze and it started to leak from I assume a freeze plug at back of engine. I did not want to split tractor so I put a can of ground black pepper in radiator. After running 4 or 5 hours it stopped leaking and has not leaked since that was 13 years ago,and I use the little tractor a bunch. Good Luck
old
01-09-2007 14:02:01
You probaly have a freeze plu the weeps a little when cold and then when it warm out or you run the engine it expans and stops leaking.
