Farmall Super C Axle Length
Joe Kimbriel
01-09-2007 12:35:56
What should the rear axle length be on a 1952 Super C? Was there an option for long axles or short axles? Is there a normal rear wheel width for this tractor? Someone cut the axels off with a torch most likely to get it through gates or out of the barn!!!!!
Thanks,
Joe
the Unforgiven
01-10-2007 06:07:43
 Re: Farmall Super C Axle Length in reply to Joe Kimbriel, 01-09-2007 12:35:56
Hey Joe, if it had 100 inch axles the housings will be longer too, there will be a parting line on the casting about 6 inches in from the bearing retainer.
Joe Kimbriel
01-10-2007 10:00:51
 Re: Farmall Super C Axle Length in reply to the Unforgiven, 01-10-2007 06:07:43
Thanks, I'll look
Berry450d
01-09-2007 15:51:40
People around here refer to the 100 inch axles as cotton axles.Maybe for a cotton picker.
farmallhal
01-09-2007 13:44:32
After my first post thought I should look in my parts catalog. Actually, the 88" and 100" axles were both optional to the standard which was 80". This should be correct as it's from the book and not my memory. Hal
Joe Kimbriel
01-09-2007 15:33:44
 Re: Farmall Super C Axle Length in reply to farmallhal, 01-09-2007 13:44:32
Thanks for the clue. I never thought to look in my parts catalog, sure enough it was there.
Thanks again,
farmallhal
01-09-2007 13:38:58
I believe the standard was 88" axles while 100" axles could be ordered. Hope this helps, Hal.
Joe Kimbriel
01-09-2007 15:13:56
 Re: Farmall Super C Axle Length in reply to farmallhal, 01-09-2007 13:38:58
Thanks, that's exactly the information I needed.
