F14 governor
Chuck Kaufman
01-09-2007 15:53:56
I had a guy rebuild my governor but I don't thunk it's assemblemed right. is the arm that connects to the main shaft supposed to be parrell to the block? mine is leaning out from block towards the tire. Thanks Chuck K.
Fawteen
01-10-2007 01:30:36
 Re: F14 governor in reply to Chuck Kaufman, 01-09-2007 15:53:56
Yes, it should be more-or-less parallel to the block. The top housing rotates on the tube. Just loosen the nut-and-bolt "setscrew" and rotate it.
I don't recall right now if the linkage arm inside the housing is keyed to the shaft or not. I think it may be, in which case the whole assembly will have to be taken out and repositioned.
If not, you can just loosen the pinch bolt on the smaller arm to the carb and rotate it on the shaft.
