Light and battery switch
Mike Broome
01-09-2007 17:16:00
I have a three position switch, frist position-I don't know ?.2 I don't know ?.3 it will turn on the lights It is a 6 Volt system, I just don't understand what all the clicks are for. I have fixed the Starter problem was a bad ground connection and thanks to all that answered you were a great help I have learned more now for later problems (maybe)
KEB
01-09-2007 19:51:01
 Re: Light and battery switch in reply to Mike Broome, 01-09-2007 17:16:00
Does the generator have a cutout relay or a regulator? If the generator uses a cutout relay, the first two positions are probably to control the charge rate, i.e., low charge, high charge, lights (always on high charge when the lights are on).
High & low charge rates are controlled by switching a resistor in & out of the field circuit. A regulator does this automatically, but if you have a cutout relay you have to do it manually. High charge to re-plenish the battery after starting, low charge to keep it charged and hopefully not overcharge it.
Keith
Jossette
01-09-2007 19:13:09
third party image
switch
Jossette
01-09-2007 19:19:05
 Re: should have spring on back for a dimmer in reply to Jossette, 01-09-2007 19:13:09
third party image
switch
Yugrotcart
01-09-2007 17:29:58
Off, Dim, Bright..... .....
