400 DIESEL WIRING
F WALLS
01-09-2007 18:30:27
I JUST BOUGHT A 400 DIESEL THE BATTERY WAS GONE I KNOW IT IS 12 VOLTS BUT IS IT POSTIVE GROUND OR NEGATIVE GROUND.
javp20
01-10-2007 10:15:36
 Re: 400 DIESEL WIRING in reply to F WALLS, 01-09-2007 18:30:27
I have two Farmall 400 Diesel's and both are 12 volt positive grounds.
Roger Mills
01-10-2007 05:33:00
If the cables are still there then hook them up to the post they fit. Then turn on lights and see if the ammeter goes to discharge, if so you are correct for the wiring. Many early diesels kept the same polarity as the 6 volt systems they just went to 12 volts for cranking power and in some cases they just turned up the generator voltage and even kept the same starter. Point is that the generator and regulator needs to match the battery polarity, and they can be either. Cars went to negative ground first and many tractors stayed positive ground for a long time afterwards. All alternators are negative ground unless specifically made to replace a positive ground generator-rare.
the tractor vet
01-10-2007 05:29:58
IF it is still stock with a genarator then it is 12 volt Pos. ground But who knows what has been done to it over the years .
Berry450d
01-09-2007 19:42:06
I went out to shed and looked to make sure My 350D,and my 450D both are 12 volt,and both are positive ground.
Berry450d
01-09-2007 19:35:59
I am not sure ,but I think if it still has a generator it is probably positive ground.
Janicholson
01-09-2007 19:32:09
Many of the MD-SMD-SMTAD-400-450 were 12v (I owned a 48 MD stock 12V). They were positive ground if stock generator system was still on it. None were Neg ground. If it has an alternator, it is 99.99% going to be Neg ground. and will smoke like crazy if hoohed up backward. Good luck, and keep us informed. JimN
Wisconsin Cowman
01-09-2007 18:52:22
If it is a 12 volt then it a a negative ground.
Jossette
01-09-2007 19:00:55
 Re: 400 DIESEL WIRING in reply to Wisconsin Cowman, 01-09-2007 18:52:22
not ALL 12 volts are neg. grounds
Wisconsin Cowman
01-09-2007 19:31:11
 Re: 400 DIESEL WIRING in reply to Jossette, 01-09-2007 19:00:55
All the 12 volt systems that I know of are all negative ground. Never in my life had I seen a 12 volt system that was positive ground. Six volt systems are positive ground. If you switch your grounds you will have some problems.
gene bender
01-10-2007 02:59:01
 Re: 400 DIESEL WIRING in reply to Wisconsin Cowman, 01-09-2007 19:31:11
There were both grounds used you just havent seen them.
Janicholson
01-09-2007 19:34:36
Sorry Wisconsin, They do exist in a variety of machines, both with generators, and alternators. (the latter are not common, but are out there) JimN
BOBM25
01-10-2007 08:33:27
 Re: 400 DIESEL WIRING in reply to Janicholson, 01-09-2007 19:34:36
Yep, my MTAD is 12v positive ground. Every old farmall diesel I've ever seen has been that way.
