C Farmall serial # tag
thumbanger
01-10-2007 16:59:49
I have a 51 C Farmall that has the rockford clutch I no there is a letter you put if it does on serial number plate where would it be and what letter. Thanks in advance
Berry450d
01-10-2007 17:08:09
 Re: C Farmall serial # tag in reply to thumbanger, 01-10-2007 16:59:49
It should have a J stamped on the tag somewhere
Yugrotcart
01-10-2007 17:06:30
The letter "J" at the end of the serial number stands for Rockford clutch.
Paul
( A popular question tonight..... .)
kfox
01-11-2007 07:20:20
 Re: C Farmall serial # tag in reply to Yugrotcart, 01-10-2007 17:06:30
I think the rockford clutch was pretty well standard factory. I haven't seen a serial tag with a "J" on it yet. Of course I haven't seen a lot. I have a 41 H with "X-21" on the tag, for the Auburn clutch. The only difference I found was the flywheel was drilled & tapped with two bolt patterns. I used a rockford when I replaced it. ken
Berry450d
01-11-2007 16:51:24
 Re: C Farmall serial # tag in reply to kfox, 01-11-2007 07:20:20
My 1953 Super C has a J on it.
