340 hydraulic line
Mark / Wi
01-11-2007 13:31:47
Any one know of an after market supplier of hydraulic lines that fit International Tractors. I am in need of the hose on the left side of the tractor, as you sit on the seat, that goes from the transmission pump to a block under the dash that feeds the power steering and touch-o-matic systems. It is about a 14 inch hose. Thanks in advance for your help.
Ken McCubbin
01-14-2007 08:29:49
 TA in reply to
Berry450d
01-11-2007 14:01:23
 Re: 340 hydraulic line in reply to Mark / Wi, 01-11-2007 13:31:47
Is it a rubber hose or steel? If it is rubber you should be able to have it made. If it is steel you can check with IH dealer they might be able to get one,if not go to salvage yard for used one.
