HV front axle spindle bearings
26Red
01-12-2007 10:27:46
third party image
Has anyone here found replacement bearings for the arched front axle spindles? This is not the wheel bearing but rather the 3 piece spindle bearing. I have tried several NOS dealer warehouses (the depot and DPNI) with no luck.
Is there a modern replacement bearing I can buy?
Here is the list of parts I need to replace:
#37: 59836D BEARING STEERING KNUCKLE PIVOT BEARING OUTER RACE #38: 55413D FLANGE STEERING KNUCKLE PIVOT BEARING INNER RACE #39 55412D RING STEERING KNUCKLE PIVOT FELT WASHER #40 D2616 BALL STEERING KNUCKLE PIVOT BEARING BALLS (3/8" chrome steel) (Same as 1110C) Any help would be appreciated....
gene bender
01-16-2007 05:46:23
 Re: HV front axle spindle bearings in reply to 26Red, 01-12-2007 10:27:46
if that is the same bearing that the w-4 uses it is out of production and has been for a long time we found one at a wearhouse in CALIF
I KNOW THAT!
01-14-2007 08:07:59
 Re: Question about putting new brake band on an M? in reply to Haas, 01-13-2007 18:46:44
See my reply to CNKS.to do the job right, you should thought.
Wisconsin Cowman
01-12-2007 13:55:48
Timken website is down. I will try to get Napa part number too.
SuperA-Tx
01-12-2007 12:46:35
Is there a place where you live that just deals in bearings where you could take it in for them to match?
I know of a place in Texas if your interested but you would have to see if you could mail it in or something. I talked to them about matching seal numbers and they said they couldnt cross match the numbers to Case/IH.
Drop me an email and I'll give you their number if you need it.
