Farmall 706 range shifter
Ridge Farmer
01-12-2007 12:30:52
I need help with a farmall 706 range shifter problem. The shift lever moves freely. I have removed the operator floor and the cam shaft moves with the shift lever. Something has come loose or off under the cover. The tractor is in 4th low and will drive in 4th low. Can I remove the cover and repair parts? I have seen an ad for about $350 for a kit to fix the problem. What's the best way to go?
Sheepdog in NE
01-12-2007 16:59:16
 Re: Farmall 706 range shifter in reply to Ridge Farmer, 01-12-2007 12:30:52
You have to take the cover off to see what you have wrong. Nothing to it except it might be stuck due to never been off. Pry bar will help that. Park brake paw should be held in the up postion with a nut or something under the linkage.Could be the shaft broke in the o-ring slot or rhe half moon key sheared off in the cam. When your in there check the rollers and springs or just put them in new to be safe.
